697
This discussion topic has been answered Discussion topic: Sky Sports UHD picture keeps stuttering
This message was authored by: tvboy55
Re: Sky Sports UHD picture keeps stuttering
I have 1,2 GB at the ee hub , a hard wired dedicated ethernet cable from the puck , via a switch with nothing else on it , into one of the ports on the back of the ee hub,  and its still has been a issue so speed is not a factor I think
Hi @tvboy55  Just so you are aware the Ethernet port on both Glass and Stream pucks is limited to 100mbps.  I have 1gb Ethernet and when I had it connected via Ethernet I got around 85mbps at the puck which was more than enough for streaming without any issues.
Thanks well aware of that fact ....... speed test using netflix , as recomended by sky , show arould 85mpbs at the puck.
This message was authored by: JRK29
I'm getting exactly the same issue. Bought a new uhd TV today and can't watch my team in uhd because of this annoying glitch.
Okay. Changed to wired connection and switched off WiFi on puck. Issue disappeared after 2-3 minutes of streaming and all now seems okay.
This message was authored by: Shall24
Sky if you are reading you really need to sort this out !!
I have had unwatchable Sky sports UHD for 4 months now, stuttering, sounds issues, picture freeezes then speeds up x100 faster to catch up. I have phoned sky on numerous occasions to be fobbed off each time. I have 700/800 mbs broadband speed and TNT UHD works great so definitely a sky issue!!
I have tried everything but still the issues remain, we are paying a premium for UHD to have unwatchable tv.  Absolutely fed up either with it . To make matters worse everytine you phone you wait ages to get through and then have to go through all the same questions again for the same generic answers. So what's the point in phoning ??
This message was authored by: chaddycox
I've been having the same problems the last few months. Tried multiple solutions with no luck. UHD juddering, none when HD.
Going to start looking elsewhere for TV platforms and sports.
Sky UHD is virtually unwatchable. Early sky stream user, 400mbs gigaclear downloads. No problems previously, now non-stop.
Please sort out Sky
This message was authored by: GimGam
Another disgruntled user here unable to watch sky sports in UHD without it juddering.  Thought we were the only ones with this issue but clearly not. Posting to follow this thread whilst I muster up the time and energy  to call sky and log an issue.
This message was authored by: DavefromtheNE
Thanks to all of you mutual sufferers and your replies but I have to be honest with this community and report that TONIGHT for the first time in absolutely months I watched the full match of Manchester City vs Fulham on Sky Sports main event in UHD and there were maybe only 2 incidences of 2-3 seconds each of a very slight stutter, the rest of the match was in perfect smooth UHD
This message was authored by: pingloss
Just turned over to 401 to be greeted by the stuttering and speed up immediately.
This message was authored by: GrandJames
Any update on this shocking service on UHD for live sports?
This message was authored by: Hoohallaha
Have the same issue. It's not an internet problem it's a puck issue. My connection is ultra fast fiber and works perfectly fine on every device apart from sky stream. It's only stutters on UHD and particularly on football. Borderline unusable unless I reboot the puck before kick off. However this only works 50% of the time. Not good enough for a product which is costing a fortune to use.
This message was authored by: Super+Anthony
It's shockingly awful tonight once again Sky on 401 and 922. Thank you again for ruining my watching. Please sort this out as it's getting rather irritating for many of us.
Agree 100% @Hoohallaha its all to do with a not very efficient Puck
(Please Note: I am Neurodivergent )
I can't even watch netflix through the puck as it keeps going black and dropping out.
Having to watch through the TVs own app, with no problems.
Seriously looking elsewhere now. I have all the apps, now just need sports through something like now tv.
This message was authored by: OldJim61
I'm (sort of) relieved to find I'm not the only one having this problem. I've only had Sky a few months and UHD worked fine for the first couple, but in the last month or so, I'm getting the "slo mo" effect almost every game. Last night's Arsenal game did it regularly, and (for the first time) I noticed the picture was really lagging behind the sound. I hope Sky can FIX this soon, instead of just telling us they're looking into it!
Answered - Go to Answer
