Discussion topic: Sky Soundbar not switching on when I start up Sky Stream
Message posted on 09 Jan 2025 12:51 PM
hi
I recently switched from Sky Q to Sky Stream. A couple of minor niggles, one is that my Sky Soundbar does not switch on when I turn the Sky Stream from standby to on. I have set up the remote control to use the volume of the soundbar with no issue, but cannot get it to switch on and manually have to do it. Some may say Sky have been talking to my wife to get more exercise, but its just annoying. Has anyone else seen this ?
Message posted on 09 Jan 2025 01:49 PM
Re: Sky Soundbar not switching on when I start up Sky Stream
Hi @reylee
As far as I am aware it should work. Ensure that it is connected as per the Sky recommends here: https://www.sky.com/help/articles/setting-up-sky-soundbox-sky-stream-puck
MikeAlanaR
Message posted on 09 Jan 2025 01:56 PM
hi
thank you for the reply, yes this is what I used on set up before. The volume controls work, just moving from standby to on, when I power on the Sky Stream does not work.
Message posted on 03 Mar 2025 05:10 PM
Have you found a soultion to this problem? I
have the same issue ,volume works fine and the TV turns on via hdmi through the sound box, but the box stays on standby.
Does anyone with a soundbox and Stream have theirs working ok?
