Discussion topic: Sky Puck sound output is too loud
This message was authored by: MikeR2
When my tv is at a suitable volume for other inputs, turning on the puck gives an almost deafening output.  It is ok if I remember to reduce the tv volume to almost nil first, but surely this should not be necessary?  Any advice welcome.
Re: Sky Puck sound output is too loud
@MikeR2 there are no volume adjustments on the pucks. A few TVs allows you to adjust the volume for each HDMI input so look at your TV's settings.to see if you can adjust it there.
Avatar for MikeR2
Thanks for getting back to me.  Unfortunately my tv doesn't have this facility.  In fact, due to the dearth of input sockets, I have to use a switcher, so three inputs share this HDMI input.  The idea was good though!
