Discussion topic: Sky Puck - remote works for channels but has stopped changing the volume and turning the tv off
Message posted on 21 Jul 2025 08:17 PM
I have sky Glass and a Sky puck (the latter in my bedroom) which for the best part of year has been working exactly as it should. However, yesterday it decided to not alter the volume nor is it turning my puck and TV off.
I've changed batteries
I've tried the 1 & 3 option (it tells me its connected - and it does indeed change channels but nothing else)
I've tried 7 & 9 and I've tried the 7 & 9 4 & 6 and 1 & 3, but no difference
Why has it suddenly stopped... my router hasn't moved, my TV hasn't changed...
Help?
Liam
Message posted on 21 Jul 2025 08:26 PM
Re: Sky Puck - remote works for channels but has stopped changing the volume and turning the tv off
@Tablespider wrote:I have sky Glass and a Sky puck (the latter in my bedroom) which for the best part of year has been working exactly as it should. However, yesterday it decided to not alter the volume nor is it turning my puck and TV off.
Help?
Liam
Best bet is to go into the puck s settings menu and select "connected devices" there's an option in there to set the remote to operate your tv
run through the options again as prompted on the screen to try and setup the remote to control your tv
Message posted on 21 Jul 2025 09:05 PM
Good idea, and I think its the one I've tried about 5 times but without success. Went through the 21 options offered and then the further 8, no joy...
But thank you
Message posted on 21 Jul 2025 09:10 PM
I've seen a few similar posts in the past month where the same has happened post a recent update . What model and make is your tv ?
Message posted on 21 Jul 2025 09:30 PM
A fair point, it's a 55" Samsung, probably about 3 or 4 years old? Flat screen smart, so not too old, but until Saturday it was all working beautifully together. I did wonder if it had overnight become incompatible but I can't see that being logical..
Message posted on 21 Jul 2025 09:32 PM
I've asked if there's any information via a post in the superuser forum regarding compatible tv models
Message posted on 21 Jul 2025 09:35 PM
UE55TU8500Lj ( I think...)
Message posted on 23 Jul 2025 06:25 AM
sky puck remote
weird thing happened.
my sky stream remote used to switch my tv on and off, but now it won't do either. any ideas out there?
Message posted on 23 Jul 2025 07:10 AM
Re: sky puck remote
@shadow971959 wrote:weird thing happened.
There's been a lot of posts like yours in the past few weeks .... what's the make and model of your tv ?
Message posted on 23 Jul 2025 07:12 AM
Re: sky puck remote
See recent list below and response
Message posted on 23 Jul 2025 08:14 AM
Re: sky puck remote
tried all tat too
Message posted on 23 Jul 2025 10:31 AM
Re: sky puck remote
The guidance received is to make sure the Stream has HDMI control enabled in the Startup and Standby menu as well as the corresponding setting on the TV, For LG for e.g its called Simplink
Message posted on 23 Jul 2025 10:32 AM
The advice received is to make sure the Stream has HDMI control enabled in the Startup and Standby menu as well as the corresponding setting on the TV, For LG for e.g its called Simplink
Message posted on 23 Jul 2025 11:58 AM
Another fair point but given that nothing has changed over the past eight months it has suddenly stopped.. no adjustments, no moving, no change in routers etc etc ... why would it suddenly stop doing it?
Message posted on 23 Jul 2025 12:28 PM
@Tablespider wrote:Another fair point but given that nothing has changed over the past eight months it has suddenly stopped.. no adjustments, no moving, no change in routers etc etc ... why would it suddenly stop doing it?
Maybe the tv itself has had an update and it has reverted some of the settings back to default ? If you could try the above I can provide feedback in the closed forum ...
