Discussion topic: Sky Puck new installation and sky oackage
Message posted on 27 Aug 2025 07:53 PM
My iPad allows me to watch sky atlantic, sky sports football and everything in my new package but on my TV it doesn't allow me to watch any of them and keeps asking me to change to UHD sound. I do this but then it still doesn't work?
Does anyone have a clue what's happening here?
Message posted on 27 Aug 2025 08:07 PM
Re: Sky Puck new installation and sky oackage
Hi @Martin260
UHD is the picture format not sound. It's sounds like your output settings are not correct. Go into settings > picture and sound and make sure your output is set to 2160p. Also depending on your your TV you may need to enable UHD on the input your puck is plugged into.
MikeAlanR
Message posted on 27 Aug 2025 08:10 PM
Thanks Mike, sorry I meant the picture quality UHD. Does the iPad then automatically adjust for this setting on Sky Go but the OLED TV doesn't?
Message posted on 27 Aug 2025 08:17 PM - last edited: 27 Aug 2025 08:18 PM
Hi @Martin260
iPad will use a fixed resolution for it's output but you need to set the puck based on TVs. The puck has to cater for hundreds of different screen types / refresh rates etc. Also might be worth letting us know what TV you are using.
This information should help: www.sky.com/help/articles/picture-and-sound-settings-sky-stream
MikeAlanR
