Discussion topic: Sky Puck isn’t connected every morning
Message posted on 10 Dec 2024 09:02 AM
Every morning when I turn on everything the Puck message in the TV screen states it's not connected to the WIFI and asks me to Get Connected.
This doesn't happen on the 2nd Puck I have which connects automatically at turn on.
Message posted on 10 Dec 2024 09:43 AM
Re: Sky Puck isn’t connected every morning
Hi @Steve101968
Try going into settings > system management> start up and standby and turn Networked Standby Mode ON and overnight power save OFF.
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
Message posted on 10 Dec 2024 04:55 PM
@Steve101968 I had exactly the same issue with my Sky Glass a couple of years ago and the solution as outlined by @mikealanr resolved the issue for me.
If my post has solved your issue please mark as an "Answer"
Message posted on 10 Dec 2024 05:10 PM
Thanks for the response.
I've checked settings and it shouldn't disconnect overnight.
Network Standby Mode is set to On
overnight Power Saving is set to Off
yet the problem continues. Same every morning ?!
Message posted on 10 Dec 2024 05:13 PM
@Steve101968 are you switching your puck off at night or leaving it on standby? It is best to leave it on standby.
Message posted on 10 Dec 2024 05:15 PM
Both Pucks are turned off. One connects immediately when turned back on but the other says WiFi not connected. Settings identical
Message posted on 10 Dec 2024 05:19 PM
@Steve101968 would you like me to escalate your original post to the Community Messaging Team who will invite you for an online chat and troubleshooting?
Message posted on 10 Dec 2024 05:20 PM
Yes please thank you
Message posted on 10 Dec 2024 05:21 PM
@Steve101968 I have escalated your post to the Sky Community Messaging Team who will send you an invitation for an online chat.
The link below explains how the procedure works
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Keep a look out for the speech chat bubble that will appear on the bottom left of your screen when you are logged onto this forum (you will need to refresh your browser from time to time until you see the chat bubble). When the blue bubble does appear you have 48 hours to respond or the chat will be automatically closed. Note replies from Sky are not instant so you will need to regularly check the chat thread.
Message posted on 10 Dec 2024 05:23 PM
Not wise to turn the power switch off or remove the plug overnight for a puck.
Just use the remote control to switch off the puck, so it stays in standby.
The puck runs on a very low power in standby and it also does updates overnight.
Switching off for a long period will disconnect it from the network and will cause problems on wake up.
A short power restart of a few minutes or a restart using the settings restart option is fine and will keep the network connected.
As above make sure you ensure you have the settings as described above.
Message posted on 11 Dec 2024 08:54 AM
Hi there! Thank you for escalating this. We have sent an invite to @Steve101968.
