Discussion topic: Sign into Sky Sports on a Sky Stream device with my Virgin Media ID
This message was authored by: Cashy1
Hi  I am a Virgin Media customer who has SKY Sports as part of my tv package. I have recently purchased a Sky Sream puck and package  as I needed  and alternative way of connecting to a TV in a room via wifi only. Am I able to sign into Sky Sports on the Sky Stream device with my Virgin Media ID vs Sky ID
This message was authored by: Ellie_TV
Re: Sign into Sky Sports on a Sky Stream device with my Virgin Media ID
No.
Why not get a Virgin Stream box instead?
Avatar for Cashy1
That was my first choice but for reasons unbeknown to me, apparently you can't have 2 wired boxes and a stream box together with Virgin. So I opted for the Sky Stream which I'm happy with, it does the job I wanted from it. Just wondered whether I could watch my Sky Subscriptions (sports & cinema) via Virgin on it.
@Cashy1  If you obtained a Stream puck through Sky these are loaned to you.
You need to have the base TV pack and Sky sports pack as part of your Sky subscription to be able to use Sky sports on the Sky Stream puck.
You can't use the puck and login to Sky sports using your Virgin Media login as that is not how the pucks work.
Avatar for Cashy1
Yes I do have a sky subscription for the Sky essential TV package. I'm not going to subscribe to Sky Sports on both Virgin and Sky, No issues I'll just watch Sky sports on the tv's in the house wired to Virgin boxes. Just wondered whether it was possible or not.
@Cashy1  unless you see a login with virgin option on the app login screen then The answer to your question is no if you want to access via sky streaming your subscription has to be fully with sky
