Discussion topic: Separated sky puck and the hub apart from each other
Message posted on 15 Mar 2025 12:44 PM
I've separated the puck and hub apart from.each other and it seems a lot better and it's not causing problems or breaking down the current netflix speed is at 32.06 mbps
Message posted on 15 Mar 2025 01:03 PM
Re: Separated sky puck and the hub apart from each other
@Jonathanphillip wrote:I've separated the puck and hub apart from.each other and it seems a lot better and it's not causing problems or breaking down the current netflix speed is at 32.06 mbps
That's good to know, it's probably good not to have the router too close to a device as it may cause interference.
Message posted on 15 Mar 2025 01:32 PM
Yes agree.
It's always best practice to have any device connecting on wifi a good six foot distance at least away from a router, extender or a mesh device to reduce any interference.
Message posted on 15 Mar 2025 01:57 PM
Does this help with speed requirements or breaks down its now reading 31.20 mbps
Message posted on 15 Mar 2025 02:41 PM
@Jonathanphillip wrote:Does this help with speed requirements or breaks down its now reading 31.20 mbps
It won't make your download speed faster that you are receiving to your router but will cause less interference which can affect the speed your devices receive.
