Discussion topic: Screen says not connected. Took on-screen advice, and went into settings then network . Nothing!
This message was authored by: IanCraig1
Message posted on 14 May 2024 10:24 AM
Followed instruction, no reset box came up. No WPS button on router.
Find out more
Message posted on 14 May 2024 11:22 AM - last edited: 14 May 2024 11:23 AM
Re: Screen says not connected. Took on-screen advice, and went into settings then network . Nothing!
@IanCraig1 If you have the Black upright hub the wps button is on the right hand side of the hub.
