Discussion topic: STV programmes not playing on Sky Stream/Puck
This message was authored by Amyshields20 This message was authored by: Amyshields20
Good Morning
I just set up my Sky Stream/Puck yesterday.
Seems to work okay generally however I can't watch any STV programmes. It shows me they are on my playlist and are available however when I select them the screen goes blank. This has happened for things on my playlist and things I'm trying to view on Catch Up. the actual live STV channel works absolutely fine.
Shows for example like emmerdale, coronation street, the long shadow.
I did see one other post with a user who had the same issue back in May, but no resolution for that customer I don't think. No recent update.
Any advice welcome! I have resorted to still using my iPad to watch all my programmes - so wondering what the use is in having sky!
This message was authored by Nand This message was authored by: Nand
Re: STV programmes not playing on Sky Stream/Puck
I also have this problem! Just set up sky glass yesterday and can't get on to stvplayer, very annoying!
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Have you tried an app refresh?
Settings > System Management > Resets & Updates > refresh apps. This process is not instant and is carried out in the background so don't expect an instant solution.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
Yes I've done this, thank you. As you say it's not instant so just waiting. Hoping it works!
This message was authored by Karen5 This message was authored by: Karen5
Hi, Did this work. Having same problem.
Hi
It worked on a puck in a different room and then once I'd logged in that way it seemed to work on the main tv, even though I had to log in again.
Thank you for the reply, I was a little scared to try it as we are still adjusting to Stream, but will now give it a go....what can go wrong, he he.
