15 May 2023 08:00 PM
My remote has been working fine since I got the stream box 3 months ago.
But now when I press up on the volume it brings up the search function. Down on the volume does nothing.
I also noticed the mic button for voice searching no longer functions.
I've tried the following:
- switching everything off and on
- re-synching the remote via settings (it doesn't work)
- resetting the remote holding 7/9 then 1/3 - nothing happens.
Any advice would be appreciated!
15 May 2023 08:50 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Alex+J+G
Try the information on the following link, if it still doesn't work after that press the "still need help" button on the last page.
https://www.sky.com/help/articles/remote-control-help-sky-glass
Thanks,
Tim
25 Jul 2023 06:48 PM
Having the same issue and have tried everything. Will sky replace the remote?
25 Jul 2023 09:46 PM
@Nick+Jones1234 wrote:Having the same issue and have tried everything. Will sky replace the remote?
@Nick+Jones1234 Yes, if the remote is faulty Sky will replace it, they replaced mine as it was chewing through batteries.
Follow the advice & link given above by @Tim+Adams and phone Sky if yiu don't resolve the issue.
If you have one available you can use a Sky Q remote whilst you wait for a replacement.
25 Jul 2023 10:09 PM
Had a similar issue following my sky remote making a small ‘pop’ sound on Saturday evening.
Replaced batteries, tried unpairing (which simply turned off the box because the number 3 button was now the ‘new’off button 🤣)
Quick call to sky on Sunday afternoon and a new remote received today.
06 Mar 2024 05:54 PM
Having the same problem, tried resetting the remote and no further....
06 Mar 2024 06:10 PM
Posted by a Superuser, not a Sky employee. Find out moreSome things to try:
Reset the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel.
You can't also try removing the batteries from the remote overnight, which has solved some peoples issues in the past.
If it is still not working have a look at the following guides:
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
