6
This discussion topic has been answered Discussion topic: Removal of unwanted channels from epg
This message was authored by: Stelian1
Hi, does anyone know how to remove unwanted channels such as the children's and Indian channels from the epg?
This message was authored by: Paul+Boland Answer
Re: Removal of unwanted channels from epg
@Stelian1
That's not possible to remove unwanted channels from a epg.
Are you not aware you can add upto 100 channels to favourites and arrange the order those channels will be listed.
Settings viewing preferences Manage Favourites
The home screen menu on Sky Glass/Sky Stream when you add channels to favourites these will then be listed beside tv guide and you can also access the favourites from the tv guide
@Stelian1
Avatar for Stelian1
Hi, thank you for your advice, much appreciated. I am aware of favourites, however it would be much easier to remove the channels you don't want rather than the laborious process of adding channels to your favourites.
regards
This message was authored by: Furgus1
Upvoting this, just some kind of market in the EPG would help to see what you have in you r package and still keep a list of what you dont have for the 'upsell'
@Furgus1  There is no vote going on, Sky won't give the option to remove channels from the EPG as these channels pay Sky large fees to be there!
Use the favourites if you only want to see certain channels
You don't need to remove them, i understand the paid placement for an upsell (I mentioned that in my comment).  Just a mark or a tick or something to show its in your package.  When you are browsing its unbeleivably annoying that you select a channel you dont have, then have to go back etc etc.  Just an idea...
@Furgus1  Thats what Favourites are for so you can add the channel you watch without the need to scroll through or select the ones you don't.
