2
This discussion topic has been answered Discussion topic: Puck in cupboard wont turn after deep sleep
This message was authored by: Tajw
I have a sky stream puck in a cupboard beneath tv (12mm mdf)
Once the puck is on -I can control it via bluetooth with the door closed ( change channel, home, voice, turn off and immediately back on) so bluetooth is working fine.
Problem comes when trying to wake up from a deep sleep ( overnight or several hours off).  Remote will not wake up puck by pressing home bitton unless the door is open.  Network standby is ON and Power saver is OFF.
I have spoken to support who have confirmed that waking up from "deep sleep" requires line of sight between puck and remote and "deep sleep" is a mode the puck goes into even if power saver is off
This implies waking from "deep sleep" uses Infrared rather than bluetooth, am i correct?
I see other have used Wake on lan packets to keep their puck awake but this no longer works. Only workaround I can see is to buy a small IR extender (£6.99 on Amazon).  Will report back once Ive tried
Avatar for Tajw
This message was authored by: Tajw Answer
Re: Puck in cupboard wont turn after deep sleep
Ive now bought a cheap IR repeater which works fine to wake up puck in cupboard
You could use a wifi smart plug, so allow the puck to go into deep sleep, but just do a smart plug power off and on sequence when you need to start it up.
The powering on in that sequence will start up the Sky Stream puck.
Avatar for Tajw
