This discussion topic has been answered Discussion topic: Playlist contents disappeared and ‘Continue Watching’ not showing
Message posted on 04 Sep 2025 01:31 PM
Re: Playlist contents disappeared and ‘Continue Watching’ not showing
Also having the same issue. It started about a week ago now. The 'recently watched' only shows Netflix shows and nothing else. The continue watching row on the UI has completely disappeared. So if I want to watch a tv show episode I have to locate the correct episode I was on and then have to fast forward to where I was last. Which means I have to pause throughout to watch the ads. Very frustrating!
Message posted on 04 Sep 2025 02:19 PM - last edited: 04 Sep 2025 02:23 PM
Hi @Matt1579 and welcome to the forum. Yes, it certainly can be frustrating. Although I have not had the current issue I have had it in the past. If you look at Post 14 above you you will see Sky are aware and are working on a solution.
Message posted on 04 Sep 2025 02:20 PM
Hi @Sussex-Stitcher @Matt1579 @ChrisBarnes1981 @Wiggins123 @martino1
Our engineers have been investigating the problem and we require some further information.
If you are still seeing the problem, can you provide the following information, please?
- Where does the Playlist problem happen? ie there's no option on the homepage or when you select the homepage icon, it doesn't display anything
- Do you see any error messages?
- Can you try the service now and post back the date/time that you've tried, for the logs to be checked?
- If you're having Continue Watching problems, what happens? ie the rail isn't there, or you can't play the content from the rail
- Are you having problems watching Live TV, On Demand, or using Apps? If so, which and what happens?
Thanks in advance, it's appreciated 🙂
I'm going to mark this post as the current answer, so that everyone has the most up-to-date information.
Kev
Community Manager
Message posted on 07 Sep 2025 08:40 AM
Playlist issue has stopped now. Now my box is just randomly freezing, total dead freeze no function nothing at all. Does it mid stream sometimes and sometimes just on the homepage.
Message posted on 08 Sep 2025 06:48 PM
Same problem, playlist is there just no programmes, no error messages, no issue with other apps, regretting getting sky stream now appalling
Message posted on 08 Sep 2025 08:32 PM
@Willoz wrote:Same problem, playlist is there just no programmes, no error messages, no issue with other apps, regretting getting sky stream now appalling
Can you see them in the manage all section of the playlist ?
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
Message posted on 11 Sep 2025 12:10 PM
Mrs patel
I am not able to have multiple shows on my playlist
Message posted on 11 Sep 2025 12:26 PM
Re: Mrs patel
@Kinjal1 wrote:I am not able to have multiple shows on my playlist
Further information needed. Which shows in particular are you having trouble adding to your playlist?
Message posted on 11 Sep 2025 12:42 PM
I can add stuff to the playlist. I can add it to a profile. But sometimes, randomly, the playlist just disappears. In other words, the shows I added are gone, and the playlist is cleared. The profiles are still there, but no shows.
That's the one problem that happens infrequently and randomly for me.
The other playlist problem(on demand): I am watching The Rookie from scratch, and if I stop watching and come back later, then I can continue where I left off (that is if the Sky Stream puck has not powered off). If I watched the previous night, and I turn it on again in the morning, it does not show me where I can continue, it only shows me the latest episode. So the rail is there, it just shows me Continue with the latest episode selected. It's as if it is saving the last watched state in static memory, and that is lost when the device is powered down (manually or automatically). The frequency of this: every time the device is powered down it loses the last watched state.
There are no error messages. Just an absence of working functionality
