Discussion topic: Pixilating telly signal weak or loss
Message posted on 05 Jul 2025 08:21 PM
Message posted on 05 Jul 2025 08:24 PM
Re: Pixilating telly signal weak or loss
@OapAlan wrote:
My telly signal keeps cutting out ever since sky tried to sell glass, why?
I suspect it's a coincidence unless Sky now send out engineers to move your dish out of position if you refuse...
Message posted on 05 Jul 2025 08:27 PM
@OapAlan
Are you seeing a “no satellite signal” message? If so check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 05 Jul 2025 08:31 PM
Message posted on 05 Jul 2025 08:38 PM
So if you haven't got Sky Q what have you got as you've posted on the Sky Q board?
Message posted on 05 Jul 2025 09:02 PM
Message posted on 05 Jul 2025 09:04 PM
I think you have Stream so I'll move your thread to that board.
Message posted on 05 Jul 2025 09:07 PM
Message posted on 05 Jul 2025 09:22 PM
@OapAlan if you open Netflix on the sky box and go to Get Help -> Check Your Network it should give a little report including what download speed the sky box is getting.
Message posted on 05 Jul 2025 09:26 PM
@OapAlan We understand your problem with technology and we will do our best to help and happy to be patient.
A couple of things to check, as it sounds like you are connected to your puck via the Wi-Fi rather than a direct Ethernet cable from your router to your puck. On the basis it is connected over the air via Wi-Fi then does your router have a direct unobstructed view to your puck? If not try if even temporarily moving things so it has a clear view. Also check neither router or puck have any objects close to them, plenty of space around them, and check your router is not near a window such as on a window sill or by a mirror. All these things can effect your connection.
Do you also know your internet speed? If not we can tell you how to check. I hope this helps.
