Discussion topic: Pixelating SKY Movies and SKY Sports
This message was authored by: rickg84
Hi there,
I've had Sky Stream for 3 months now and only started to encounter issues over the past week with bad pixelating (every 3-5 seconds) when watching Sky movies and Sky Sports channels. I have 2 pucks, one is connected via Ethernet cable and the other is on our wireless network. Internet is with Plusnet and I get an average of 900mbs around the house. Having checked Netflix the wired puck is getting 940mbs  and the wireless 870mbs. It's literally unwatchable. I've reset, factory reset and nothing changes. I can stream UHD sports on other apps no problem, it's just the Sky content. Any ideas?
Rick
This message was authored by: Greenfingers001
Re: Pixelating SKY Movies and SKY Sports
Hi there @rickg84 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: MatCostick
Mine doing exactly the same on two different pucks, hard wired to router.   I have a 3GB Community Fibre link that is working fine on all other devices, so 100% not a local or ISP network issue.  Has something changed over the last week in terms of software updates?
Avatar for rickg84
Something must have changed. Also noticed it on other channels last night too and when I was trying to watch Prime via the app on Stream. Having to watch via the TVs apps and don't experience any issues when streaming live UHD content. 100% not a network issue, has to be the puck. My guess is memory issues, perhaps due to problems with caching data. Annoying, paying for something that's unwatchable right now.
Rick
Totally agree it's next to useless at the moment especially with the ongoing sound sync issues.
I just refreshed my apps in settings and restarted and it does appear to have improved things but I have been here before.
Last chance saloon for this crap tech, I think I will go to NowTV.
This message was authored by: Jd89
Yeah this is a problem I have had since August last year, ive got a sky Q box and all movie channels and sports channels will either be green or pixelated or both and even the sound drops out at times then i get a black screen with a message saying no satellite signal, its horrendous that anyone should pay for channels that are not watchable , I've called Sky several times about this issue finally getting a technician out on to try and fix it
This is the Sky Glass forum which is a different product to Sky Q, you should try posting there to get in front of the right community or a mod might be able to move your post.
