6
This discussion topic has been answered Discussion topic: Picture freezes but sound carries on
This message was authored by: SlackDarren
Every night since we got the little puck the ITV news stops but the sound carries on.
Im on all the default settings have the deviced connected via a ethernet cable 2 foot long into my HX220 tplink router running via fiber.
Please any ideas were to start and fix this.
Thank You.
Very Kind Regards
Slack Darren
This message was authored by: Fothergill1 Answer
Re: Picture freezes but sound carries on
@SlackDarren I note you are using Ethernet so go to Settings > Network > advanced settings and then make sure you have turned off WiFi with the toggle switch.
While you are in the Settings menus take the opportunity to go to Start up & Standby and turn ON Networked Standby mode and turn OFF overnight power settings.  Although this is unlikely to be relevant to your current issue it certainly helped me with some other issues I had.
Once you have done this reboot your puck by unplugging it and waiting a minute before plugging it in again.  It will then take about a minute to reboot.
Hopefully this will help with your problem.  Good luck🤞.
Avatar for SlackDarren
Level 2 icon
Thanks for your answer, I shall give it a try tonight during the local news when it usually fails.
Thanks again.
Very Kind Regards
Slack Darren
Who is your ISP?
Level 2 icon
My ISP is yayzi i have fttp via city fiber and we are on there 900Mbits service.  All works pretty well for other devices.
Still testing the sound issues.
Thanks.
Very Kind Regards
Slack Darren
Level 2 icon
Looks like this is fixed. thanks
Very Kind Regards
Slack Darren
Level 2 icon
Sky puck Fails to load any programs. Possably long.
Ok a little background. I have Yayzi fttp. With a Sky Puck and a Toshiba fire TV.  TV Works a treat no problems found with it. Connected via copper straight into the router.
Now the puck also connected via copper straight into the router.
Have changed some setting as recomended for a LipSync problem.
Changed: Settings menus take the opportunity to go to Start up & Standby and turn ON Networked Standby mode and turn OFF overnight power settings.
The puck reports the following versions.
Build Version QS024.012.00p
Hardware model IP061-ef
UI Version 20.276.024.05
Platform Version 6.9p16s1
Now the problem after coming home from work and turning on get "The program failed to load", "There was a Techinal problem" or simply returns to the front screen.
Tried many reboots, But nothing only thing that seems to work is  try again 10 minutes later.
I haved missed a few messages and displays that appear. Will try and note them down tomorrow.
Is this anything to-do with UHD and Doly atmos ?
Thanks for the anticipated help.
Very Kind Regards
Slack Darren
