Discussion topic: Picture and sound are continually interrupted and pausing for no reason
Message posted on 28 May 2024 11:11 AM
Just set up Sky stream and changed over from Sky go.
The programmes are continually pausing and are unwatchable
Message posted on 28 May 2024 11:49 AM
							Re: Picture and sound are continually interrupted and pausing for no reason
How have you connected your puck to the internet, via Wifi or ethernet?
Can you open the Netflix app on the puck, go to Get Help -> check your network and run the diagnostic to find out what download speed the puck is getting
Message posted on 28 May 2024 07:05 PM
@Sandra1963 wrote:Just set up Sky stream and changed over from Sky go.
Who is your ISP?
What is your router's sync speed?
What is your Puck's connection speed?
