8
This discussion topic has been answered Discussion topic: Out of sync sound on S4C channel 172 on Sky Stream
This message was authored by: singsongfun
I am getting out of sync sound on Welsh channel S4C on Sky Stream channel 172.
All other channels are fine, it is only a problem with S4C.
Are others also getting this?
Any fix?
Many thanks
This message was authored by: mikealanr Answer
Re: Out of sync sound on S4C channel 172 on Sky Stream
@singsongfun
When you say reboot experience has shown this doesn't always clear faults. The puck needs to be powered off at the mains for a few minutes. The entertainment OS version is largely meaningless, the software version of the puck is the version starting with QS. Entertainment OS version 1.3 refers to functionality released by Sky.
Edit as a work around you can also watch through iPlayer.
MikeAlanR
Hi @singsongfun
Fine here on 104 (I am in Wales). In would try powering off for a few minutes and try again. Failing this try changing your audio output settings to PCM.
MikeAlanR
Avatar for singsongfun
Many thanks.
I have tried rebooting and box is on version 1.3 Entertainment OS.
Don't really want to go to PCM sound as that will degrade sound on all channels.
Can anybody outside of Wales, watching S4C on 172, confirm if the sound of sync?
Many thanks
@singsongfun
MikeAlanR
Thanks. Have powered off the box and waiting for some minutes.
Many thanks for the work around of watching S4C on BBC iplayer 👍
Thanks for your help.
I turned the power off for the puck and left it off for 20 minutes.
Now back on and the sound sync seems ok.
I hope I don't jinx it!
Cheers 👍
This message was authored by: Caza3
I'm sick of this puck it j u st isn't working it stalls constantly in my area it's just not fit for purpose
