Discussion topic: Out of sync sound and sounding under water
Message posted on 05 Feb 2025 01:02 PM
The sound on all channels is out of sync and on most of the channels the sound is like under water. I've tried changing all the leads but the problem is still there,
Message posted on 05 Feb 2025 01:53 PM
Re: Out of sync sound and sounding under water
@AndyBok wrote:The sound on all channels is out of sync and on most of the channels the sound is like under water. I've tried changing all the leads but the problem is still there,
Tried rebooting the puck? Remove the power from the wall for a minute or two then power it back on.
Also check the audio output settings on the puck. Try Auto/PCM/Dolby Digital/Dolby Digital+/Passthrough and see if it's the same on all of them. If it is then it may be a faulty puck and you'll need to ring Sky for a replacement.
