Discussion topic: Our puck isn’t working it’s dead I think we need a replacement
Message posted on 26 Jul 2024 08:54 AM
Our puck isn't working we have tried turning it off using our controller on our other puck and that worked. There's no lights on the puck it's dead. I think we need a replacement
Message posted on 26 Jul 2024 08:56 AM
Re: Our puck isn’t working it’s dead I think we need a replacement
@Susan102 Have you checked the power cable is fully seated? Have you truied turning off at the wall for 2 minutes?
Have you checked the power socket isn't at fault by using another socket?
Message posted on 26 Jul 2024 09:02 AM
Yes we have done all that the puck isn't lighting up
Message posted on 26 Jul 2024 12:27 PM
Have you tried turning it on using the button underneath the puck as well? Just as a way to check it's not a remote related issue
