1
This discussion topic has been answered Discussion topic: No sound on my TV
This message was authored by: Talent1999
No sound on my TV
Occasionally when I turn on I have no sound at all. I have to shut down on the wall and then after 30 seconds turn it back on. Why does this happen and what can I do about it?
This message was authored by: Stephen+Mourton Answer
Re: No sound on my TV
@Talent1999   Are you using the sound direct from your tv, or a soundbar etc?  Have you gone into 'Settings' then 'Picture & sound' and checked the settings there?  Also rather than turning off and on the power while is 'Settings' us the 'Restart' option instead.  Does you router have direct line of site to your puck? Is your internet speed good?  Any of these may well effect your sound, worth a try anyway.
