This discussion topic has been answered Discussion topic: No sound on my TV
Message posted on 03 Jun 2025 08:49 AM
Occasionally when I turn on I have no sound at all. I have to shut down on the wall and then after 30 seconds turn it back on. Why does this happen and what can I do about it?
Message posted on 03 Jun 2025 04:22 PM
@Talent1999 Are you using the sound direct from your tv, or a soundbar etc? Have you gone into 'Settings' then 'Picture & sound' and checked the settings there? Also rather than turning off and on the power while is 'Settings' us the 'Restart' option instead. Does you router have direct line of site to your puck? Is your internet speed good? Any of these may well effect your sound, worth a try anyway.
