Discussion topic: No connection to tv - tv in in bedroom works fine- have wifi otherwise this computer wouldn't work
This message was authored by: Dud-see
Have disconnected / waited/ reconnected still no signal to tv.  Over the last few weeks signal has dropped out repeatedly.
Swapped the sky boxes round in case that was the problem- No works well on second tv
This message was authored by: Jporch316
Re: No connection to tv - tv in in bedroom works fine- have wifi otherwise this computer wouldn't wo
Hi @Dud-see
does whichever puck is plugged in the furthest from your router have the same issues?
if so it is likely a weak wifi signal in that room. A cheap option would be some powerline adapters to link the furthest away puck directly to the router
or it maybe worth speaking to your internet provider to see if you can get some boosters to give you a bigger wifi area
some other tips to try are to make sure your router is out in the open
make sure the sky stream pucks are out in the open
