18 May 2024 03:24 PM
Sky tv keeps freezing and loosing sound on one tv i cannot get sky at all
18 May 2024 03:37 PM
@Westchapelton25 wrote:Sky tv keeps freezing and loosing sound on one tv i cannot get sky at all
If you have Stream pucks then you need to make sure they are all connected to a fast and stable broadband network. Is your broadband functioning correctly? What speed do you receive?
18 May 2024 03:50 PM
What is your router's sync speed to the internet?
How many Pucks do you have?
How many do you try to run simultaneously?
What is the speed to the internet for each Puck, measured using the Netflix network check, when only one of each is powered on?
