Discussion topic: My sky remote doesn’t let me flick through Chanel’s but lets me turn the box on and off.
This message was authored by: Matthew28
I've turned my sky on but the remote won't let me flick through any Chanel's or do anything. I've tried resetting it but nothing happens how do I fix this?
Re: My sky remote doesn’t let me flick through Chanel’s but lets me turn the box on and off.
Re-Pair the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel.
A third thing to try, take the batteries out for several hours before replacing them.
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
