Discussion topic: My sky puck keeps freezing on netflixs
Message posted on 06 May 2025 08:37 PM
My sky puck keeps freezing on Netflix's when I try watch a film ect it freezes. Does sky puck work better on sky wifi?
Message posted on 06 May 2025 08:45 PM
Re: My sky puck keeps freezing on netflixs
Message posted on 07 May 2025 06:28 AM
As above.
Sky Stream works with any broadband ISP.
Can you do a network speed test on each of your Pucks.
Launch Netflix on your pucks (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test a handful of times, say over an hour period between tests.
What is your speed?
Sky Ultrafast + using Sky SR203 hub. Sky Mobile unlimited data. Sky Protect kit tester.
Message posted on 07 May 2025 10:39 PM
Hi my connection speed is 43.33Mbps
Message posted on 07 May 2025 10:41 PM
Hi my connection speed is 43.33 Mbps
Message posted on 08 May 2025 07:54 AM - last edited: 08 May 2025 07:57 AM
@Graypat1 wrote:Hi my connection speed is 43.33Mbps
In theory that speed should be fast enough however the stream boxes are data hungry and interference with other devices can cause issues Try an app refresh to see if it helps @Graypat1
To refresh apps on Sky Stream, navigate to Settings > System management > Resets and updates > Refresh apps. You'll see a message confirming the refresh, then press "Dismiss" to return to normal viewing.
