5
This discussion topic has been answered Discussion topic: My remote control made a pop noise like something blew in the circuit and now doesn't work
This message was authored by: Harlos78
I was just sitting with my remote on my lap and it made a pop sound like something blew on the circuit, when I opened the back there was a wird smell and now it doesn't work properly
This message was authored by: Munkeh Answer
Re: My remote control made a pop noise like something blew in the circuit and now doesn't work
Hey,
That dose sound strange but give the Sky Stream team a call and they will be able to send you a new remote out and return the faulty one so they can investigate in case it a faulty batch hope this helps :).
Two Stream Pucks (Both ethernet)
OGI 900 FTTP (900Mbs), eero Max 7 & 3 x eero Pro 6E
If my post has solved your issue please mark as an "Answer"
@Harlos78 There have been a number of reports of this happening with the remotes over the last couple of months.  Unfortunately they are massed produced and of very poor quality.
[removed]
If you are lucky enough to have one available you can use a Sky Q remote while you wait for the replacement to arrive.
Moderator note: removed URL
Hey,
Avatar for Harlos78
Hi , yeah I contacted them and they're sending a replacement but didn't say anything about sending broken one back 🤷🏻‍♂️
This message was authored by: PSC133
Sky are not requesting the return of faulty remotes.  I think that they already have a significant amount of evidence that point to the fact that the remotes are substandard.
@Harlos78 They don't want the old remote back.  When I needed a replacement remote it was before the online form was available so I had to phone and ended up doing so four times before I received the remote.  The online form is so simple and quick.
Answered - Go to Answer
