10 Mar 2024 12:19 AM
10 Mar 2024 12:30 AM
Hey,
That dose sound strange but give the Sky Stream team a call and they will be able to send you a new remote out and return the faulty one so they can investigate in case it a faulty batch hope this helps :).
10 Mar 2024
12:29 AM
- last edited:
11 Mar 2024
03:34 PM
by
Chloe-W22
@Harlos78 There have been a number of reports of this happening with the remotes over the last couple of months. Unfortunately they are massed produced and of very poor quality.
[removed]
If you are lucky enough to have one available you can use a Sky Q remote while you wait for the replacement to arrive.
Moderator note: removed URL
Hey,
10 Mar 2024 01:54 PM
Hi , yeah I contacted them and they're sending a replacement but didn't say anything about sending broken one back 🤷🏻♂️
10 Mar 2024 03:22 PM
@Harlos78 wrote:Hi , yeah I contacted them and they're sending a replacement but didn't say anything about sending broken one back 🤷🏻♂️
Sky are not requesting the return of faulty remotes. I think that they already have a significant amount of evidence that point to the fact that the remotes are substandard.
10 Mar 2024 03:26 PM
Posted by a Superuser, not a Sky employee. Find out more@Harlos78 They don't want the old remote back. When I needed a replacement remote it was before the online form was available so I had to phone and ended up doing so four times before I received the remote. The online form is so simple and quick.
