Discussion topic: My good journey to Sky Stream from Sky Q
Message posted on 11 Aug 2025 05:58 PM
Re: My good journey to Sky Stream from Sky Q
thanks - funnily enought that is the exact screen I'm trying from and it presents me with this one;
https://www.sky.com/glass/buy/stream/ineligible?code=q.customer.ineligible
Message posted on 11 Aug 2025 06:47 PM
@AKT69 wrote:thanks - funnily enought that is the exact screen I'm trying from and it presents me with this one;
As you're a Sky Q customer you can't order online @AKT69 you have to phone to order.
Message posted on 19 Aug 2025 04:29 PM
Great review thanks - really comprehensive. Quick question. Are you able to watch previous recordings on your redundant skyQ box or do you lose all access?
Message posted on 19 Aug 2025 04:36 PM
@PaulN4 wrote:Great review thanks - really comprehensive. Quick question. Are you able to watch previous recordings on your redundant skyQ box or do you lose all access?
All Sky Q equipment belongs to Sky and has to be returned. You will lose access to the recordings when your service ends and switches over to Stream anyway.
Message posted on 19 Aug 2025 04:48 PM
Hi @PaulN4 and welcome to the forum. @BenJoBanjo is 100% correct. To get around this, when I moved from Q to Glass / Stream I used my mobile phone to take photos of my entire recorded library on the Q box. When I had my Glass TV setup, with the exception of just one programme, I was able to locate every other programme which I then added to my playlist.
This made the transition relatively painless.
Good luck 🤞
Message posted on 19 Aug 2025 05:11 PM
Fabulous thanks.
Message posted on 09 Nov 2025 09:50 AM
Unfortunately this does not appear to be an available option to existing Sky Q customers - I just get the message "You are already on Sky Q which is the best for you blah blah etc ".
VERY frustrating as I am moving to a rental and cannot take SKy Q with me. So will cancel Sky completely.
Message posted on 09 Nov 2025 10:09 AM
Moving from Q to Stream is an option but has to be done by phoning, not online. There are potential complications with current minimum Q terms and the existence of a rolling monthly Stream subscription.
Message posted on 18 Jan 2026 12:37 AM
Hi we moved from sky q to stream puck , and we set up the tennis to playlist for sky sports plus and sky sports tennis and it only did one and both had different games so wanted to see both the next day or other days just bits and been told nothing wrong with system as can not play list sky sports plus so as when you set sports tennis up from guide it series links plus as well and it decides what it does do ,so very unhappy with it . Also play listed Star Trek next generation on sci fi channel and it saved it on paramount which we have not got . So not working for us so looks like back to sky q for us .
Message posted on 03 Jun 2026 01:07 PM
I know this is an old post but thank you for sharing, it is most helpful. I used to ahve Sky+ when in a house share many years ago and when our road had fibre installed in March I decided to get Sky Broadband with TV and im really happy with being able to ahve Sky TV without a sattelite dish, though I do miss not being able to record.
Sky Full Fibre 500mbps
