Discussion topic: My Pul does not connect to wifi although there is no issue with my wifi
This message was authored by: Alina17
Message posted on 26 Aug 2025 09:23 PM
Hi , one if our puks does not connect to wifi although there is no issue with the wifi connection itself.
Message posted on 26 Aug 2025 11:28 PM
Re: My Pul does not connect to wifi although there is no issue with my wifi
@Alina17 If one works fine, then something wrong with the other!
Find out more
Message posted on 27 Aug 2025 08:17 AM
@Alina17 wifi signal strength varies due to the layout of your home and how it is built. As a test swap the two pucks over if the issue moves with the puck its a dodgy puck if it doesn't then you need to consider getting a wifi extender.
