Discussion topic: Lg ur81006lj sky pucks remote wont sync
This message was authored by: Djc22
Message posted on 21 Mar 2025 05:34 AM
Hi all the volume and on or power off for my TV won't work The model number is 55. UR81006LJ has anyone else experience issues and how did he fix it if they did?
Message posted on 21 Mar 2025 07:27 AM
Re: Lg ur81006lj sky pucks remote wont sync
Hi @Djc22
Try following this guide to see if it helps, there's often issues with syncing to LGs for some reason https://www.sky.com/help/articles/remote-control-help-sky-glass-lg-tv
