Discussion topic: Intermitting WiFi connection and BT WiFi hub showing a fault
Message posted on 12 Nov 2024 04:24 PM
Intermitting WiFi connection and BT WiFi hub showing a fault.
Message posted on 12 Nov 2024 04:43 PM
Re: Intermitting WiFi connection and BT WiFi hub showing a fault
@LeeDavies6388 If your BT hub is showing a fault have you thought about contacting them?
Message posted on 12 Nov 2024 05:01 PM
I wasn't sure if this had to go through sky or not with them being my provider. Don't know who I would contact either i.e. phone number.
Message posted on 12 Nov 2024 05:29 PM - last edited: 12 Nov 2024 05:33 PM
To be clear: is BT or Sky your ISP (broadband provider)?
Is the 'BT WiFi hub' perhaps an Openreach ONT (white wall box with LEDs for an FTTP connection)?
ISP routers don't tend to have an LED specifically labelled 'fault' but there's at least one model of ONT which does.
Message posted on 12 Nov 2024 05:44 PM
My provider is Sky through open reach
I have constant static red fault light on my white router box.
I have no consistent access to services
Message posted on 12 Nov 2024 06:07 PM - last edited: 12 Nov 2024 06:08 PM
OK: that's probably not a 'router box': it's likely to be an Optical Network Terminal (aka 'fibre modem')
Is it the model below?
Message posted on 12 Nov 2024 06:25 PM
Yes that is correct it is that box.
Message posted on 12 Nov 2024 06:46 PM
OK: the fault light is almost certainly unrelated to any broadband issues.
It's actually an indicator that the separate Battery Backup Unit is no longer capable of holding charge.
Message posted on 12 Nov 2024 06:49 PM
https://helpforum.sky.com/t5/Broadband/Alarm-light-is-solid-red-on-openreach-box/m-p/4643562
