Discussion topic: I've got Sky Stream. Need help putting leads in the right place
This message was authored by: Errol-George29
I need guidance on putting the correct leads in my new Sky stream box
Avatar for Errol-George29
Re: I've got Sky Stream. Need help putting leads in the right place
I've placed various leads in the new Sky Stream box. However, I'm a little unsure where the aerial goes from the TV to the stream box
This message was authored by: peter-marlow+1966
The aerial  stays in the back of the tv, not the puck
P c marlow
There is only 2 leads to connect (if you intend to connect the stream puck to the internet via WiFi).
1) is the power cable for the puck which connects the puck to an electrical socket.
2) is the hdmi cable which connects the puck to to it TV.
Both of these cables are completely different shapes. An HDMI cable is the same shape both ends so you just need to find the HDMI socket on your Tv to plug it into.
It doesn't, and Stream cannot output video signal over its aerial socket to a television set equipped with an analogue or digital tuner.
The aerial socket is for digital terrestrial television (DTTV) reception through the  Stream box in countries where this is required by national broadcasting regulation (in Italy, for example)
