Discussion topic: I’m waiting for a new remote control how can I use my I phone while I wait
This message was authored by: Ann140
It's says I can use my I phone as a remote control while I wait for a new one but when I go into settings it's just saying error all the time
This message was authored by: Jporch316
Re: I’m waiting for a new remote control how can I use my I phone while I wait
Hi @Ann140  you can't use your phone as a remote. Im afraid you will need to wait for the remote
A replacement remote normally takes only a few days or so to arrive.
In the meantime, if you have an old Sky Q remote, you can pair that temporarily. Of course, a few button actions will not be the same or some are on a different button.
If you have an LG TV with a 'magic' remote, you can use the LG remote to control your Sky Stream box.
This message was authored by: Dazzasky
Depending on what TV you have, you may be able to use your tv remote. @Ann140
I suspect that's an inappropriate reference to the remote control functionality of the Sky Go app when used with Sky Q, particularly if you found it through an AI search result.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/
