2
This discussion topic has been answered Discussion topic: I am losing my connection now the box sits behind my television mounted on the wall.....
This message was authored by: San1959
either when I switch apps or switch off the television for the evening.
This message was authored by: mikealanr Answer
Re: I am losing my connection now the box sits behind my television mounted on the wall.....
Hi @San1959
Hiding the Stream puck behind the TV may interfere with the WiFi signal. The Puck needs a strong signal to function correctly. One setting to try to resolve the signal going when you turn the box off is to go into settings > startup and standby > turn Networked standby mode ON and overnight power saving OFF.
However if you are loosing WiFi during normal operation your only options are to connect via ethernet (turn WiFi off in settings) or reposition the puck.
MikeAlanR
Hi @San1959
MikeAlanR
Avatar for San1959
Thanks @mikealanr
