4
This discussion topic has been answered Discussion topic: How to purchase sky box office on sky stream puck?
This message was authored by: Farenden2024
Hello. I just wondering how to buy sky box office events on sky stream?
This message was authored by: Fothergill1 Answer
Re: How to purchase sky box office on sky stream puck?
@Farenden2024 No you can order on the Sky Puck using the remote 👍
If you look at the link I provided and select the option "Buying a Sky Box Office Event" and then select "Sky Glass or Sky Stream Remote" it gives the instruction to order through the puck.  It actually says to do the following:
  1. Press Home on your Sky remote.
  2. Select the event from the menu.
  3. Enter your Sky TV PIN, if enabled or select Purchase.
I would still follow the link as there is other useful information.
Good luck and enjoy your box office programme 😀
@Farenden2024 Welcome to the forum.  I have never purchased a Box Office event myself but the following link should answer any question you have on the subject.
https://www.sky.com/help/articles/sky-box-office
Avatar for Farenden2024
Do I need to call sky and tell them I would like to order sky event on my sky stream puck?
