Discussion topic: How can I connect a Sky puck to an Epson EH-TW650 projector and Sharp HT-SBW182 soundbar
This message was authored by JimW99 This message was authored by: JimW99
I have tried a HDMI to HDMI Audio connector box, using an optical cable between the soundbar and connector box but i am getting no audio.
This message was authored by CoffeeDrinker This message was authored by: CoffeeDrinker
Re: How can I connect a Sky puck to an Epson EH-TW650 projector and Sharp HT-SBW182 soundbar
Looking in the manual for your soundbar at https://www.sharpconsumer.uk/audio/htsbw182/ it suggests the following:
"While in HDMI/ARC/OPTICAL mode, if there’s no sound output from the unit, you may need to activate PCM signal output on your source device (eg. TV, DVD or Blu-ray player)."
Try setting your Stream box to output PCM Stereo in Settings > Picture and Sound > Sound > Digital audio output HDMI > set to PCM Stereo.
Sky Glass & Stream Puck customer w/Sky Entertainments & Netflix, Sky Cinema, Whole Home & UHD/Dolby Atmos add-on.
