Discussion topic: Every single channel sound and picture is out of sync
Message posted on 14 Dec 2024 06:49 PM
Every single channel sound and picture is out of sync tonight anyone have the same problem?
Message posted on 14 Dec 2024 07:37 PM
Re: Every single channel sound and picture is out of sync
Message posted on 14 Dec 2024 09:05 PM
@Chenwoo the suggestion from @Dazzasky will hopefully resolve your sync issue but if it continues after the restart/reboot then try different audio settings. Go to settings > Picture & Audio > Audio; generally PCM or Passthrough help with sync issues.
Message posted on 16 Dec 2024 03:25 PM
People are saying go to menu and change the setting . Sorry wrong it doesn't change the problem. A number of channels are still out of sync.
