Discussion topic: Ethernet connected puck says “No Wi-Fi” every day when I first turn it on.
This message was authored by: Shifty+Weasel
I have a Sky Stream Puck which has been factory reset and then set up from scratch to use Ethernet not WiFi.  It has the WiFi switched off, maintain connection overnight switched on and Eco switched off.  I've rebooted and Reset but the problem remains,   I give it 5 secs and press Home and the Ethernet connection is there and working.  Connection is through an Omada/TP Link managed switch so I can see the Ethernet connection remains live at all times from the flashing lights.  I just need the puck to stop looking for WiFi......
Re: Ethernet connected puck says “No Wi-Fi” every day when I first turn it on.
@Shifty+Weasel  have you turned the wifi off on the puck, when you do this you need to restart the puck
Avatar for Shifty+Weasel
Hi, yes, I've done that, and also checked that WiFi is still showing as switched off when the puck turns back on.
