Discussion topic: Ethernet cable
This message was authored by: Super+Anthony
Ethernet cable
What's the best one to buy for stream. CAT 6 or 8?
(Please Note: I am Neurodivergent )
Re: Ethernet cable
@Super+Anthony  Both are overkill as the pucks only have 100mbps ethernet ports.
Cat 5 will be sufficient.
Re: Ethernet cable
You will be fine with a cat 5e cable and above for Sky Stream.
But, would recommend now going for at least a cat 6, Sky Stream cannot make full use of its full speed potential yet, but it does offer much improved crosstalk and noise interference in our busy households.
On Amazon and other places, I have bought cables from Ultra Clarity cables (like  connecting my ONT to router over a many feet run) and also if you prefer the flat type for runs behind your equipment and skirting runs, try those or the normal round cables form Kenable.
I have one Sky Stream box connected with a kenable cat 6 flat cable and had no issues.
My main Sky Stream box is connected via wifi, also with no issues.
Avatar for Super+Anthony
Level 11 icon
Re: Ethernet cable
Thank you. Brought  6 one
Level 11 icon
Re: Ethernet cable
Update from last post. I was just told by a tech individual from a shop that a CAT 8 will still work and won't make it worse and is compatible. He also mentioned if anything, will make it run better
This message was authored by: rg99
Re: Ethernet cable
Cat 8 is designed to work with devices at both ends that have screened sockets. The Puck doesn't and most routers don't, so it's no better than Cat 6.
Re: Ethernet cable
Almost certainly not, but his profit would be improved by the cost difference...
Cat8 is server-room technology for switch-to-switch patching on 10GbE ports and entirely unnecessary for domestic cable runs.
Level 11 icon
Re: Ethernet cable
Looking at Amazon, there is not much price difference between the two though, but thank you @TimmyBGood
Going to try the CAT 6 one though as suggested
This message was authored by: rscott
Re: Ethernet cable
Personally, I'd get a cat 5e cable for under £2, rather than spend £6 on cat 6.
Cat 6 makes sense if everything is gigabit, especially on longer runs or if it's an electrically noisy environment, but for domestic use, it's usually overkill.
I have several managed network switches within my home network and none report noticeable error levels with cat 5e.
Level 11 icon
Re: Ethernet cable
Thank you @rscott
i had already brought the 6 though, but never mind. Compared to the 8, i haven't noticed much difference. In fact the 8 had better picture it looked like
This message was authored by: Padam_Padam
Re: Ethernet cable
Thank you @rscott
The category of ethernet cable will have zero effect on picture quality.
Re: Ethernet cable
Thank you @rscott
Ssh. Don't tell the people paying £500 for an "audio grade" network switch 😀https://www.kjwestone.co.uk/product/chord-co-english-electric-8switch/
That's the entry level product - the really gullible can spend £2k on them.
Re: Ethernet cable
@rscott wrote:
Thank you @rscott
Hilarious. Reminds me of those 'experts' in Currys who try and force incredible gold plated HDMI cables costing upwards of £80 on unsuspecting customers, claiming it'll improve their picture/sound quality.
Level 11 icon
Re: Ethernet cable
Maybe it's just being neurodivergent which makes me think that!!
 What exactly are the differences? @Padam_Padam
Re: Ethernet cable
It's easier for the mind to play tricks like that. When you buy something you're told is better, you want to believe it... 😁
This will explain the basics:
https://www.digitaltrends.com/computing/different-types-of-ethernet-cables-explained/
All a Sky Stream puck cares about is receiving a stable broadband signal. As long as it gets 35Mbps or above consistently then it's happy.
I used a very cheap cat 5e cable on my Puck for a year and it was totally stable. Never had buffering or anything caused by a network issue. The issues I had were all hardware/software or server based. All the image processing is done on an entirely separate chip, completely unnaffected by the network.
