2
This discussion topic has been answered Discussion topic: Drama channel technical fault with channel
This message was authored by: Jonathanphillip
It just went off again blue screen earlier today and now its done it again stating technical fault with channel please wait whilst we load your programme separate issues technical fault then please wait whilst
Re: Drama channel technical fault with channel
@Jonathanphillip where you hit an issue with a single channel or orogramme but the box operates normally on other channels report the issue to Sky's viewer relations team at viewerR@sky.uk they will get the issue checked out.
Avatar for Jonathanphillip
Level 6 icon
Thanks @Chrisee  for your response 👍 it's done it again at 145 this morning same thing and then again this afternoon at 1300 same thing 😀 technical fault and then  please wait its seems fine after that and tonight see how it goes might drop out this evening or go like that till early hours
