2
Discussion topic: Drama channel technical fault with channel
This message was authored by Jonathanphillip This message was authored by: Jonathanphillip
It just went off again blue screen earlier today and now its done it again stating technical fault with channel please wait whilst we load your programme separate issues technical fault then please wait whilst
This message was authored by Chrisee This message was authored by: Chrisee Answer
Re: Drama channel technical fault with channel
@Jonathanphillip where you hit an issue with a single channel or orogramme but the box operates normally on other channels report the issue to Sky's viewer relations team at viewerR@sky.uk they will get the issue checked out.
