Discussion topic: Disney plus (+) error code 1026 fix
This message was authored by: Hyper1979
If you try to log into Disney + and get error code "1026" do the following steps to solve it.
https://help.disneyplus.com/en-GB/article/disneyplus-en-us-error-1026
Go on to the live chat as shown on this screenshot...
At first you will get a bot/Ai asking you questions. Go through the steps it goes through but get to the point it connects you to an actual person.
When it connects you to a real person tell them "I can't connect to Disney+ through Sky, I have an error code 1026"
They'll ask you some questions but all you need to do is get your IP address from https://www.whatismyip.com/
Disney will reset your IP and it should then work.
