This discussion topic has been answered Discussion topic: Device switched to 576p and now won't allow UHD to be enabled
Message posted on 22 Feb 2025 04:24 PM
Switched on the TV this afternoon after watching this morning and everything was fine, and the menus were visibly blurry.
Odd I thought, so went to resolution settings and it had set itself to 576p (my TV is a Sony 4K) for some reason.
I can switch it to every resolution up to and including 1080p, but when I select 2160p the options area of the menu goes blank as if it's going to try and switch but it then just sits there doing nothing.
I can press Home or Back and it goes back to the resolution options.
To be clear, the screen stays on when I do this, it's like some kind of UI bug or something. ibe tried a power off and a restart via the UI but nothing.
Message posted on 22 Feb 2025 04:34 PM
For anybody that comes across this in future, I hard reset of the TV seemed to fix it.
