Discussion topic: Connecting Sky Stream to Viera TV with Component ports only
This message was authored by: Parthag
Hi, I have a sky stream connection with HDMI output. My panasonic Viera TV does not have HDMI input - It has the 5 port component connection. What is the right connector that will allow me to connect the two devices?
Avatar for Parthag
Re: Connecting Sky Stream to Viera TV with Component ports only
 These are the component input AV ports my TV has...
This message was authored by: Jon34
Have a look on Amazon for -
HDMI to Component/YPbPr converter
Sorry was meant to share a link
https://amzn.eu/d/i6hruMK
Something like that
@Parthag  Are those the only inputs?   I feel that using the component inputs may cause an issue with HDCP not being picked up, which could mean no picture from the puck or an error message on your TV.
What is the Model of your TV?
The component inputs are analogue and won't have anything to do with Hdmi copy protection.
The box or cable that you would use to convert the signal has to be compatible, the product I posted a link to does not mention if it is compatible with hdcp, it does say it is hdmi 2.0 complaint of which copy protection is a part of.
So if you don't want to replace the TV, it's worth trying, send it back if it doesn't work.
I would imagine that the puck would either not work at all, or it may display an error, that being said you may find a converter that supports copy protection.
Avatar for Parthag
Thank you folksI was able to find an HDMI compatible port connector which resolved the issue for me. Appreciate your responses!
