Discussion topic: Can I use my sky satellite dish with sky stream
This message was authored by: Chris309
Can I use my sky satalite dish with sky stream @Skyhelp
Re: Can I use my sky satellite dish with sky stream
@Chris309  no you can't I'm afraid
you have tagged a fellow customer who unfortunately used an unfortunate name rather than sky support
This message was authored by: Mister_Dalek
They are completely different services.
A satellite dish is needed for Sky Q. A broadband connection is needed for Sky Stream. Neither will function without them and the services cannot be mixed in a single household.
This message was authored by: CoffeeDrinker
In a word, no. The Stream box itself streams content over the internet, either via WiFi or Ethernet, and has no interfaces for cables from a dish.
Additionally, Sky will only allow a Stream subscription or a Sky+HD/Sky Q subscription at a given address, not both. So even if you have a Q and a Stream box, only one can work with the appropriate subscription.
Sky Glass & Stream Puck customer w/Sky Entertainments & Netflix, Sky Cinema, Whole Home & UHD/Dolby Atmos add-on.
Depends on the LNB on the dish and whether your Smart TV can be connected to a sat dish🤔
If you have Sky Q  the LNB will need to be changed ... if you have Sky+ the LNB can supply a sat signal to a Smart TV with a DSat tuner😉
