07 Dec 2023 01:56 PM
Anyone using yayzi. Just checking for problems before i buy.
Also instead of using Sky Stream Hardware, Is there an App i can use on my Smart TV.
Thanks.
07 Dec 2023 02:00 PM
No: the only related apps potentially available on a smart TV would be Sky Store or NowTV
07 Dec 2023 02:01 PM
@SlackDarren wrote:
Anyone using yayzi. Just checking for problems before i buy. Stream will work with all providers so can't see a reason why yayzi would be any different.
Also instead of using Sky Stream Hardware, Is there an App i can use on my Smart TV. No, you need to use stream pucks for each TV.
Thanks.
Posted by a Superuser, not a Sky employee. Find out moreThere isn't a app per se as the Sky hardware is essentially a custom OS and a collection of other apps.
the nearest alternative would likely be NOW TV if you don't want the Stream box.
