16 Dec 2024 02:14 PM
I just got sky stream with Netflix included in my bill but I want to add Netflix to my laptop as well from my stream account
16 Dec 2024 02:57 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Cem86
When you sign in to netflix with your existing username and password billing will switch to Sky. You can then carry on using netflix on your laptop and stream.
See: https://www.sky.com/help/articles/apps-on-sky-q-and-glass-using-netflix
MikeAlanR
Posted by a Superuser, not a Sky employee. Find out moreYou can access Netflix from any device, you just need to login to Netflix using the email and password you used when you created your Netflix account.
16 Dec 2024 03:18 PM
How do I add my sky stream Netflix to another device any advice helpful please I not good at this
16 Dec 2024 03:37 PM
