Discussion topic: 32in tv/monitor uhd
This message was authored by: sky1946
32in tv/monitor uhd
Does anyone know of a 32 in tv/ monitor that will play sky sport uhd?
This message was authored by: Jporch316
Re: 32in tv/monitor uhd
Hi @sky1946
when a tv is that small (generally!) they only display 1080 as the difference in picture quality between 1080 and UHD is not that noticeable
Avatar for sky1946
I totally agree on definition but it's the hdr element I'm looking for and that would be evident and a great improvement
@sky1946 there are several 32inch UHD sets  around simply run a search on a retailer you trust likecthis one I ran on Richer Sounds https://www.richersounds.com/tv-projectors/tvs-accessories/tvs-by-screen-size/up-to-32-tvs/?sort=PRI...
Not got any experience of these sets myself so check out any reviews you can. The  set has to have a HDMI input which supports HDCP 2.2 for a Stream puck to connect. Also check the set supports HLG HDR which Sky use.
